Are you looking for Solas HR Titan 4-Blade Prop, Pressed Rubber Hub / SS, 13 dia x 19, RH? We found best price for you. Go to link below to buy the Solas HR Titan 4-Blade Prop, Pressed Rubber Hub / SS, 13 dia x 19, RH for the lowest price.
Solas HR Titan 4-Blade Prop, Pressed Rubber Hub / SS, 13 dia x 19, RH Review
I see Solas HR Titan 4-Blade Prop, Pressed Rubber Hub / SS, 13 dia x 19, RH it's stylish, my friend all have it so I decided to get one too. It's the coolest propellers of all time!
Solas HR Titan 4-Blade Prop, Pressed Rubber Hub / SS, 13 dia x 19, RH Description
Enjoy excellent cruising performance with the Solas HR Titan propeller. Each Solas propeller is precision-manufactured with quality materials for stronger, thinner, and smoother blades. Pressed rubber hub is molded in an octagonal shape to absorb vibration and reduce slipping. The stainless steel HR Titan prop provides great stern lift and acceleration. Constructed with a high rake blade with large cupping design, the HR Titan features a powerful thrust and very smooth performance. Propeller also provides increased speed and fuel economy in the engines mid-range. Ideal for ski boats, offshore fishing boats, and family cruisers.
Related posts
- Solas HR Titan 4-Blade Prop, Pressed Rubber Hub / SS, 13.5 dia x 13, RH
- Solas HR Titan 3-Blade Prop, Pressed Rubber Hub / SS, 14.75 dia x 18, RH
- Solas HR Titan 4-Blade Prop, Pressed Rubber Hub / SS, 14.25 dia x 17, RH
- Solas HR Titan 4-Blade Prop, Pressed Rubber Hub / SS, 14.1 dia x 19, RH
- Solas New Saturn 3-Blade Prop, Pressed Rubber Hub / SS, 10.1 dia x 13, RH
- Solas Saturn 3-Blade Prop, Pressed Rubber Hub / SS, 10 dia x 11, RH
- Solas New Saturn 3-Blade Prop, Pressed Rubber Hub / SS, 9.25 dia x 9, RH
- Solas New Saturn 3-Blade Prop, Pressed Rubber Hub / SS, 14 dia x 23, RH
- Solas New Saturn 3-Blade Prop, Pressed Rubber Hub / SS, 10 dia x 15, RH
- Solas New Saturn 3-Blade Prop, Pressed Rubber Hub / SS, 13.25 dia x 17, RH
- Solas Lexor 3-Blade Prop, Pressed Rubber Hub / SS, 15 dia x 21, LH
- Solas New Saturn 3-Blade Prop, Pressed Rubber Hub / SS, 14 dia x 19, RH
- Solas New Saturn 3-Blade Prop, Pressed Rubber Hub / SS, 15.6 dia x 11, RH
- Solas New Saturn 3-Blade Prop, Pressed Rubber Hub / SS, 10.3 dia x 12, RH
- Solas Saturn 3-Blade Prop, Pressed Rubber Hub / SS, 9.3 dia x 11, RH
- Solas New Saturn 3-Blade Prop, Pressed Rubber Hub / SS, 14.3 dia x 17, RH
